hi I just replaced door with new 6 panel internal door pre primed cheap one .The door is bowed in middle is there any way of sorting this it is bowed 6mm
ease the door stop by 3mm top and bottom if that dosnt help ease the striking plate a mm or 2
your door is unlikly to get better it may get worse but having to spring it shut should keep it in check
I had a similer problem on site once when door rep was called out no help atall.said we had not primed top and bottom of door therefore moisture had affected doors,all had bowed as you said, we did safe a couple by laying on flat surface put board across and blocks on top
