Afternoon all,
Just noticed the garage wall on the house I've just bought is bowing inwards slightly at the middle of the wall.
Garage is made with single skin brick walls on three sides, with a block wall shared with the neighbour. Flat roof. Concrete base is undamaged. The wall in question is the single skin brick wall on my side of the garage, that runs the length of the garage. There is a pillar about half way down which consists of single bricks and doesn't appear to be tied to the outer skin.
The wall is bowing inwards by about 1.5 inch about halfway down/across. The pillar has separated from the outer skin and is also bowing inwards.
On closer inspection the mortar on the outer wall has deteriorated considerably, especially the first course of bricks under the damp course and at the top where the somewhat rotten fasica boards are. The pillars around the garage door are also somewhat knackered, especially at the top/bottom.
I think the mortar has weathered to the point where the weight of the roof has caused the wall to bow.
Do I have any options other than pull it all down and start over? I take it walls can't really be straightened?
I was thinking of supporting the roof with adjustable scaffolding poles and replacing the affected the wall with blocks.
Alternatively, how about building a second skin from blocks on the inside, then grinding out/tuckpointing deep on the outer skin?
