I have just had a roof done and the roofer has lined the box gutters with a rubber sheeting, designed for flat roof areas. One of the box gutters does nt drain and now has a pool of standing water in it, till the water reaches a certain height then the excess only will drain out. I did know this particular section does nt drain and mentioned it to him. However it has nt been rectified. Section is about 8 feet long and about 10 inches wide. Is this a major problem? Should the rubber be able to hold this permanently ?[/img]
