BOX LINTEL ADVISE
14 Mar 2011
Kent
I want to make a 1700MM meter opening in a loadbearing wall , which supports the a wall above and in the loft two timber supports rest on the wall.
is a standard load box lintel ok?
wall is 100mm
opening is 1700 mm
lintel is 2100mm
with a 150mm bearing each side , the lintel will rest about 1 meter each side of the opening
Will depend on wall construction, height, size of roof bearing onto it, if floors bear onto it and other factors.. 1700mm opening should be do-able with an off the shelf lintel but specing which one will require a lot more info..
