either solvent weld the plumbing waste or cut an acsess panel to a neat tile size and grout the panel edge using a silicone then if and when access is required you can cut the silicone and re-grout in the same way afterwards.
pitt paul riley
_________________________________
Moderator
website url removed these can be shown in your profile
