As we were desperate for hot water - had a new wall mounted boiler fitted in the kicthen last oct. Regret had to fit onto the breeze block/brick and now want to plaster the rest around it.
What's the best solution and should you = box in a boiler (the vent goes straight outside thro wall)
Is there a product you can buy ie a metal enclosure (as it is adjacent to hob)
if possible ??
Presume this should be done before plasterers come - if not how will they work around it ?
if possible ??
