boxing in pipes
4 Aug 2008
London
going to box in 3 pipes to the boiler in a bathroom. its away from the bath. if ive used battons to create the stud work around the pipes. if i use plywood, what size ply should i use if im tiling it?? would 6mm be thick enough to use as plywood then tile over??
is plasterboard good for this job??
I only ever use PB; it's easy to cut, easy to fit & you can tile straight onto it.
does it matter what size PB i use or ply??
in a bathroom can i tile directly to PB without tanking it, due to humidity etc?
Use 12mm plasterboard; as I said I would not use ply but if you do, check the adhesive manufacturer’s instructions as some may require plywood to be primed.
You only need to tank PB wet areas, behind a bath or in a shower; ideally I would normally use Moisture Resistant PB in a bathroom but if it’s just a box around some pipes I cant see it being a problem.
are we now expecting RC to end up tied up in a wardrobe in 20 years time?
:eek: :eek:
Assume that’s me as we have another RC :?: . I have got a couple of rather “alternative” friends (don’t go there :eek: ) but God forbid. Wardrobes, rope, belts; all bit of a strange do that & in Thailand as well. Something very similar has happened a while ago before but can’t remember who it was now (singer I think) but is sounds a bit iffy to me. :confused:
Shame, I liked David Caradine & always thought he was underrated; he was a prolific actor but didn’t always chose his scripts very well. I was a very religious follower of “Grasshopper” when it was current.
yep your RC, the other one is rough i take it.
i agree about carridine, a shame, i wonder if we will ever know what happend.
are you thinking about micheal hutchince?
