hi all, this is my first post and very rearely attempt anything to do with electrics apart from swapping like for like components but could do with a bit of advice.
apologies if i get anything wrong.
i'm swapping a single socket over to a more decorative one, but when i removed the exisitng socket there was 4 red wires, 4 black and 4 earths all going directly into the back of the socket, which looked a bit random and i couldnt get all the cable into the back of the new socket. i looked up a few circuit diagrams but they all look way to neat.
i bought some cable which i think was 27amp 2.5mm2 for sockets from b&q and some large connector blocks.
i put all 4 of each wires together into one side of the connectors and ran a single wire off the other side of each to the back of the new socket.
it all seems to work and it doesnt make me dance when i use it but wondered if its ok.
is it true that if i get the wires back to front the water in the kettle will get colder rather than hotter when i switch it on, i only ask as when i wired up the electric light switch the wrong way and connected the live to the outer casing, when i switched it on everything went black for a while
any advice much appeciated
