brass bath trap connection
18 Dec 2003
hi,
just about to install new bath, the waste is the pop up type and the p trap is made from brass with a small length of brass pipe on the outlet. would you suggest just using a waste compression fitting to connect the outlet on the trap to the plastic waste pipe .
below is a link to a similar trap but does not have the pop up waste.
thanks
http://www.blueriband.ltd.uk/catalog.php?itm=90500&n=Brass+P-trap
