Morning,
I have a slight problem which i'm hoping that you guys can offer some advice...
I accidently cut a 3mm nick in a 22mm central heating pipe (non combi) under the floorboards of a bathroom.
Whats the best way to repair the problem because the nick is on the side of the pipe next to a joist and right on a gradual 20deg downward bend in the pipe, i think rules out a JG 2mm speedfit repair kit as this is long and rigid. Access is fairly limited as there's the joist & another pipe 10mm away from it. I've seen a 22mm flexible pushfit repair kit from, aahhm, B&Q..
Would this be the best way of getting over the bend but would it be ok as a permanent repair ?!?!?!?
Any advice or help would be greatfully appreciated as its a bit cold in the house at the moment
