I need advice on a cheap and cheerful heavy duty drill/ kango that can help me bring out a drain pipe for a ground floor shower.
I need to drill a hole from my outside brick wall, then into concrete filled cavity, then concrete block on the inside and then through 30cm length of concrete floor to make way for a 40 mm plastic drain pipe for a new shower that I am installing downstairs?
Have already done the 50mm hole through the brick wall (just outside) using my 500W black & decker hammer drill but I would not risk that one for any more into concrete.
Would this one from screwfix help:
http://www.screwfix.com/p/direct-power-bs26s3-5kg-sds-plus-drill-230v/58494?_requestid=646851
The 50mm drill bit I am using is the following TCT core drill:
http://www.toolstation.com/shop/Pow...ll+Bits/TCT+Core+Drill+50mm/d80/sd1190/p90061
I also have the extending arm for both SDS and HEX drills for these TCT drills.
Your advice is highly appreciated. Thanks in advance..
