We are having a bathroom refit and are adding underfloor heating (just 150w version) but there is no easily reachable spurs to connect the heating system to.
There is, however, a 32A ring cable passing below the floorboards. Is it acceptable to cut this ring cable and connect the underfloor heating directly to the ring using WAGO clips inside a WAGOBOX (all rated at 32A)?
Due to the limited space for the run of the underfloor heating cable we can only get 1.5mm T/E to connect to the ring, is that also acceptable?
Whilst I appreciate this is not the "ideal" practice the paramount question is would this installation be unsafe?
The ring is already protected by an RCD at the CU.
Many thanks.
Pete.
Many thanks.
Pete.
