Hi, I need some advice if possible on the best type of membrane for a timber framed structure for a garden office.
I was going to have the stud wall, membrane, battens, then ply cladding sealed with Osmo oil. Parts of the cladding might be open joint cladding with vertical battens, but am aware some of the membrane behind will be visible in the shadow gap, so need black membrane without all the branded writing all over it.
Heard Tyvek is a bit overpriced as it's the one everyone goes for / knows about, but isn't necessarily the best.
I am also unsure if the flat roof (1:60 pitch) requires membrane? Was intending on cold roof with the insulation between rafters, then air gap, then OSB and EPDM on top.... Maybe Vapour barrier before plaster ceiling or at least use foil backed insulation instead.
Any advice much appreciated.
