Brick acid stains
11 Jun 2021
What chemical cleaner can get rid off or even lighten brick acid stains on gable harling.
Cheers, I actually sprayed a bad leak from the boiler in the loft with brick acid and did not rinse quickly enough and it's burned the light colour harling a shade of light brown.
There isn't one.
Brick acid is intended to clean bricks, and specifically to remove mortar/cement marks from bricks by dissolving the cement.
Flinging brick acid directly onto mortar or similar substances will destroy it. You can't clean it off, as there is nothing to remove.
