Morning all, hope you're all enjoying the lockdown and getting lots done around the house !
I've got a brick shed (mainly dense concrete blocks) and I'm looking to convert it into a "summerhouse"
It's 5m long X 3m wide with pitched roof - all water tight. T'was build before I move in. Its down the end of my garden right next to boarder so don't want to knock it down and start again as I'll probably have to move it due to planning and would cost 20k for something new.
There's no DPC and I doubt the floor has a DPM either.
Plan is to put external insulation on - either batten, celutex, DPM and clad with wood or ........ block foam insulation (glue and special screws maybe 90mm) skim and then clad with wood ( I like the wood effect).
Inside put batten on floor and celutex then OSB then wooden floor ?
Issue/advice. Not sure about whether I need to "tank" the walls and floor. It does get a very small bit of damp in the cornered occasionally.
Should I tank walls and put DPM down before I put floor insulation down ?
Also re the external insulation anyone tried the batten, celutex and clad method. Not so sure about it.
Obviously I'll plaster inside and out celutex in-between rafters etc.
All advice welcome. I'm a novice but fairly handy at most things - plastering etc.
