I'll try and give as much info as possible, so please bear with me....
I have just moved into a new house that has a brick built outbuilding halfway down the garden. At the moment, there is a 4mm armoured cable which appears to have been spurred from the downstairs ring in the dining room. The outhouse side of the armoured is straight into a a double socket (Power Breaker Safety RCD type). This then supplies a single wall mounted light. The armoured run is approx 10m form spur to outbuilding.
I want to turn this building into a workshop so would ideally want 2/3 pendant lights with 60w bulbs max and 3/4 double sockets. I have a brand new MK 2 way CU with 63A RCD 30ma and a 6amp and 32amp MCB which I would like to fit. Is it possible to take a 2.5mm te from the power breaker into the new CU then use the breakers for the lights and sockets. 1.5mm for the lights and 2.5mm for the sockets on a radial???
Many thanks in advance
Ray
Ray
