Hi, i am looking into building a brick garden office / gym. Just electrics, no gas or plumbing. I was initially thinking of building it out of brick and block, so a double wall with cavity, but one of the builders mentioned i could build it with a brick outer layer and stud walls filled with insulation inside for a lot cheaper. The builders said the walls will be thinner too, 150mm, and i am a bit tight for space. Question though, is 150mm enough for this type of building?
Doing a bit of research online it looks like you need all the below, totaling at least 240mm
100mm brick
50mm air gap
breathable membrane
9mm OSB board
20mm air gap
50mm PIF insulation
vapour barrier
12mm plaster board
final plaster finish
Question is, is the above overkill for a garden office / gym?
Interested in peoples views.
100mm brick
50mm air gap
breathable membrane
9mm OSB board
20mm air gap
50mm PIF insulation
vapour barrier
12mm plaster board
