Brick grade requirement for dwarf wall build
13 Aug 2010
Derbyshire
I need some advice as to the brick requirements at the various levels of a dwarf wall for a conservatory. Basically what I would like to know is, do the first courses below ground level have to be engineering bricks? or can I use the facing bricks that I am using for the rest of the wall which are F2 rated. As I understand it the bricks above ground level up to DPC have to be F2 rated, is this correct? My final question, on the internal leaf of the wall, if I use blockwork is there any special requirements below ground level. Thanks in advance.
No they don't have to be engineering bricks as long as they are frost resistant. If they are in the ground they are likely to remain saturated for long periods of time so it's also prudent to ensure that they are S2 rated.
most concrete and AAC blocks can be used below ground level, but check the manufacturers specifications to be sure.
Also make sure you use a strong (minimum 1:4) mortar.
Some frost rated bricks are crap above ground let alone below. London bricks come to mind, but are not the only ones.
I've just googled (searched for and found) some Birmingham based reports from D&T surveys and RICS surveys, and both use the term knee wall with respect to sub-floors and attics.
Little people, & others, find the term dwarf to be rude, annoying, insensitive & actually vindictive once one knows better.
Verne Troyer got very upset the last time he heard Prof. Brian Cox talk about a dwarf star...
