Hi everyone - new to the site - PLEASE can I have a little advice? I'm an amateur round here...
I'm having a party-wall built as part of a kitchen extension. The builders have used engineering bricks up to the DPC at 150mm (that's where they've got to today). My neighbour is angry because he wants London Stock bricks (ie. expensive) facing him, not three layers of engineering bricks - he reckons the builders are just trying to cut costs.
We have a party wall award that verbally specifies London Stock brickwork. However, the plans (as approved by the council, and copies of which are attached to the party wall award) do indeed specify engineering bricks below the DPC. So the PWA basically gives conflicting guidance.
Now the builders are saying this is a building regs. requirement - which I'm not sure is the case. So here are my questions:
- is this a building regs. requirement?
- even if not building regs reqt. is it best practice; would it be poor construction to use London Stock bricks below the DPC?
- what should I do?
I have 2 options:
- tell the neighbour he has to live with it because the PWA is unclear, and anyway the plans came first and have been published; also I want the security of engineering bricks below the DPC
- tell the builders they have messed up, they should have followed the guidance in the PWA, and they have to undo a day's work
Grateful for any thoughts! Thanks
- what should I do?
I have 2 options:
