Hi
I am about to brick up an external door in an external cavity wall. Both leaves are brick with a 75mm cavity (1960’s build). Two items that I need some advice on are as follows:
1. The cavities at either side of the opening are closed with brick – do I need to cut the brick out to fully expose the cavity?
2. Will it be okay to use thermalite/breeze blocks on the inner skin? I have plenty left over from other work. Just worried about cracking between the existing brick and the new block as they are different materials. The internal walls will be fully plastered so would some EML nailed to the thermalites before plastering eliminate cracking? I will be putting wall starters in to anchor the blocks.
Comments would be much appreciated.
Cheers
Cheers
