Hello,
There's a grating in my understairs cupboard, about 1m above ground level, that vents directly to the outside. Currently it's used as the tumble dryer vent (as it was when we bought the house) by the tumble dryer's hose being bolted to the grating and then the space around stuffed with newspaper. This has always been an annoyance when the weather gets cold as the drafts are terrible, and this year I'd like to do something about it. The obvious thing (to me anyway) is to remove the grating, brick up the hole and put in a proper shuttered vent for the tumble dryer.
However, I'm a little wary of this as I don't really understand why the grating would be there in the first place, and don't want to obstruct it if it's doing something important. Most of the ground floor is suspended timber with venting to the underfloor void, as you'd expect, but this grating is halfway up the wall, and the floor of the understairs cupboard is concrete anyway. Solid walls, so nothing to do with venting a cavity or anything. Any ideas?
Many thanks,
Jack
Many thanks,
Jack
