Bricklaying with soft washed sand?
12 Nov 2012
Bedfordshire
I've got some 'soft washed sand' from the local builders merchant and have been using it to lay about 14m2 of brick/blockwork. I've been finding the mortar very difficult to work with, the water seems to come to the top pretty quickly ,and i keep having to mix it with the trowel every time i pick a bit up.
The mix is pretty standard, 1:5 plus a bit of plasticiser, mixed in cement mixer, but I just cannot get the "buttery" texture i was anticipating? Am I wasting my time with this sand??
Th sand is light in colour, yellow perhaps, and pretty fine.
Cheers in advance.
Nick
If its washed its probably plastering sand and so will have little or no 'fat' It will be very unpleasent to lay more than a few blocks with.
More plasticiser might help but if you over dose it the mortar will be very weak.
Thanks for the response, do you know what else i can use this for apart from rendering, rather than wasting it?
Sand blinding i suppose, or laying water pipe.
Paving? Weak mix concrete?
Use it for anything but brickwork.
Another problem used that this mortar is very rigid when set, and makes walls liable to crack.
Ok, thanks for the info.
Might try blending a sample 50:50 with a proper building sand to see what sort of mix it produces, otherwise it'll be going in the ground one way or another!
Its good for pointing paving. Can be mixed 50:50 with grit/sharp sand for mortar for laying paving on.
