- Joined
- 9 May 2004
- Messages
- 128
- Reaction score
- 5
- Country
Hi all,
Two questions for you fine folks:
1) I've got a bare internal brick wall, solid with no damp, on a 1930's house. Am I ok to PVA then give it a coating of bonding followed by two of multi or should I be rendering it first then two coats of multi? I've read about hygroscopic salts and that rendering first is the only way to avoid the brickwork showing through.
2) I also have a chimney to cover. Although the fire has a >98% chance of never being used, the missus would like to be able to use it if she so wishes...I'm looking at a lime render mix, but will the finish be rough as old boots and look odd against the rest of the plastered walls in the room? Should I render right up to the ceiling or just immediately around the fire itself - if so, how do you blend the render/plaster to make a seemless join?
Thanks all,
Nick
PS I'm well aware that rendering is much harder than plastering and the strong likelihood is that whatever route I take, I'll end up chipping it all off anyway and getting someone in to do it properly, but I want to have a go - I'll never learn unless I try.
Thanks all,
Nick
