My mother-in-law's toilet was leaking at the flush outlet from the cistern. I dismantled it and found that the water level was two inches above the line – the cistern had been going down on to two bits of brick, one large pebble and a piece of rubble at the base of the cistern, and the balllcock's progress was hampered by two water savers (like large bags of salt). Over the years this had presumably forced the plastic ball higher so that the water filled two inches above the line, defeating the object of having water savers in the first place. In any case with the design of the sewers in the area, it is important for the waste to be flushed through with a fair quantity of water, otherwise blockages can occur - she was told this the last time a Dynorod man had to come out and clean the sewer. With the high cost of cleaning since the council service was farmed out, I would have thought that a little bit extra spent on metered water was worth it. There’s also the hygiene issue – not to be indelicate, my mother-in-law gets diarrhoea and sickness quite often, so needs a full flushing toilet.
I am interested in other people's view of why the seals, or rather the sealant, had failed after all this time.
My best guess as to the cause of the leak is that the plumber who installed the toilet (about 15 years ago?) used plumbers’ mait which gives a good seal but hardens with age. Every time the toilet was flushed the bricks, which have sharp edges, bounce up and down. Every now and then the corner of a brick would hit the base of the flush valve, loosening the seal. Just an idea.
I dismantled all this and re-assembled without the bric-a-brac as it were, and used Fernox sealant, which is flexible, so should be able to stand rough treatment. It would be better if whoever put the bricks in didn’t put them back. And you are only supposed to put one water saver bag in anyway, not two. I have uploaded a picture of what was in the toilet cistern.
Oh, and of course the isolator tap sheered off in my hand, it had obviously not been used in decades and had been painted over many times. A job for another day I think.
