Hi peeps... I hope someone can give me some good advice as to what I should about this. I've included pictures so that you can see what the situation is.
I'd laid laminate flooring in my living room/dining area, and due to both 'room's being a different height, there's a gap in the middle between the two, as you can see:-
I've got a plank of wood that I'm using so it's a little less un-sightly, and I was hoping I could use it somehow to bridge the gap permanently. I'd obviously get it varnished a similar colour to the rest of the floor. Unless there are any other netter alternatives? Here is the wood:
The trouble I'm having with the plank, is that the way the floor is, means it's not a straight-forward two height cut off... it's kinda gradual. Here's a pic I drew that shows it:
I hope someone can advise the best way forward for me.. as I'm a total DIY beginner. I just any solution that would look good.
Thanks a lot!
Thanks a lot!
