Hi all,
I recently switched out the originally installed Bristan 1901 taps (which were probably as old as the house - 20 odd years) with some newer versions as they had started to make awful noise when used and started to stick, all went well enough and the new taps worked fine (although the water pressure around here is a bit fierce, so they can be a bit enthusiastic).
However, one of the taps (the most frequently used) has now started to drip endlessly - I can't imagine that something has gone wrong with the tap so soon, but thought it would be worth a check-in - are Bristan usually good quality? Are there alternatives that I could look at that could be more reliable? The taps were not cheap, but I had accepted the cost with the idea of a like-for-like swap being the most straightforward and worry-free fix.
Thanks,
TFT
Thanks,
TFT
