We would rather like to start taking showers again, now that the worst of the winter is over!
A professional plumber installed a Bristan shower mixer-unit here a year ago and at first it worked fine - although the water was never as hot as we would have liked it.
I understand from the instruction booklet that the mixing of the hot and cold water coming into the unit is controlled by some kind of expanding/contracting wax mechanism.
Slowly the maximum temperature began to decrease until last autumn the unit just wouldn't put out water that was warm enough for a shower. The maximum temperature was lukewarm or less!
Since then we've been happily having baths! But now that the "summer" is here, I'ld like to fix this problem.
I have detached the unit to see if the filter was blocked where the hot water enters the unit. It isn't.
If I switch the unit on, the hot-water inlet pipe becomes very hot with the water inside it, proving that hot-water is reaching and entering the unit from the Combi boiler downstairs. But the reasonable mixing of hot and cold that we had when the unit was fitted just doesn't happen any more. Only a LITTLE of that hot water is being taken by the unit, being mixed with cold, and being put out as tepid.
Have been in touch with Bristan and the so-and-so's have said they will send an engineer and possibly replace but ONLY if I first provide credit card details! I can see the possibility of a Bristan engineer turning up, fitting a new unit, but finding some way of relieving Bristan of the blame and thus charging my credit card!
Has anybody any advice?
We saw this problem coming before we got the new bathroom put in and we asked the fitter to install a manual unit with two taps, hot and cold. He convinced us this would make life a misery for people taking showers - with people having to rapidly adjust the taps if someone flushed a loo or ran a tap somewhere else in the house while the shower was being used. But we wish now we had stuck to our guns. How reliable are these units that rely on a blob of wax behaving itself year-in and year-out?
Thanks.
Eddy.
Thanks.
Eddy.
