Britonny II - Hot Water Problems
11 May 2004
I have a Brittony II wall mounted boiler for the hot water in my house. This was working fine until recently - now when a tap is turned on the water is either still cold or luke warm or sometimes hot. It often takes a number of attempts to get hot water. When I look at the flames through the view port on the boiler often the flames are roaring away yet still no hot water. I'm keen to have some idea of the problem before getting in a plumber so i can at least have some level of conversation with them. Any info greatfully received.
The diaphragm in the water section is stretched and not fully moving the pin that brings on the main gas and so not heating water properly . Half hour repair and about a tenner for part
Thanks namsag - sounds like I should be able to do it myself. Are diaphrams standard sizes? How do I know which to buy as I'd rather do that before removing the old one to save being boilerless. Know of any drawings online?
There is a couple of different diaphragms that fit the britony correct one can be got by having the GC number of aqppliance and wether LP or HP model. Not really a diy job as if the pin is damaged during removal and relacement of water section the appliance can stay on when the tap is turned off and results in BANG.
ok - thanks. I'll call a plumber but at least I can give an idea of the job that needs doing.
Spot on, that was the problem - diaphragm now replaced and hot showers once more!! Thanks again.
