britony 2t water heater
29 Dec 2010
Yorkshire
hi
need help with a britony 2 t water heater its giving luke warm water,changed diapharam, did not make any difference,so was advised to replaced gas section, yet again still only getting luke warm water even slowed the flow of water down made only very slight differnce,heat exchanger was changed a few years ago due to it leaking, dont know what els to check other that the gas pressure from the meter, any help would be appreciated
thanx
Get a RGI to do all the checks, instead of chucking parts at it. Such a simple appliance.
that was the thing i did unfortunatly couldnt get to the core point
new update - problem seems to be sorted called british gas to check pressure from gas meter and found the regulator on the gas meter was faulty they changed it and all seems fine at the moment,
THe Britony may be a "Simple" appliance but they can be a real Bar***ard, we have been having a nightmare with one of these this week, we have fitted a new Water section and spindle, make sure all of the water section parts are clear of scale build up
we have found that it is easier to remove the complete Gas/Water assembly from the heater and build it up on a bench
But of course this must be done by a RGI only ;)
