hi
i've got a britony combi 80 which keeps firing up then cutting out after a few seconds, pump and fan both seem to be working fine ,i took off the outer casing then removed the 4 screws and took off the inner casing and boiler works fine with both these removed . every time i screw the inner casing back on it cuts out and goes through the same procedure again
any help would be greatly appreciated
