Got these error lights about 15 minutes ago as I heard boiler go off, pressure a bit low in middle of red so topped it up using cold filling loop
Boiler goes through start sequence, you can hear fan come on, but then goes into 40 80 flashing lights again
Boiler appears to sound like its not trying to ignite after fan starts, then goes back to 40 80 flashing light error
Water pressure is now slightly above 1 bar and holding, left boiler switched off for 5 minutes but goes back to 40 80 error each time after fan comes on
Suggestions on here seem to be its the air pressure switch at fault, any way of testing this before I go and order a new one later
