Hello all. I need to identify a part that is broken in my boiler. It is part of the water flow restrictor and is a small white plastic part that is spring loaded and in normal operation seals up the hole in the flow regulator. When hot water is called the water flow lifts this part from its seat ( after the diaphragm has operated the valve ) and allows the water to flow. When the tap is off the spring returns this part to its original position. This part is only about 1/3 inch accross with a longish thin spike on one end.
I have the boiler schematics but every time I try and order this part I get something else instead.......( NB this is the WHITE one for a 100SE )
[/img]
[/img]
