I have a problem with the above boiler. You have to turn the taps on full to get the hot water to come out. When the tap is turned on low, the actuator moves, but does not go down enough to operate the microswitch that starts the burner and pump. Water is not as hot as it should be suggesting to me that the 3 way valve us not opening fully. Could this be a dodging actuator, or could it be the valve sticking and not allowing the actuator to operate properly? Can the valves be cleaned or just be replaced?
Thanks,
Richard
Thanks,
Richard
