I have had loads of problems with my brittony comib boiler over the last year and a half. Changed the pump, changed a pressure switch thingy (can you tell i'm no plumber) and also had to replace a cracked part.
Today when I was going to do the washing up i turned the tap on to get hot water. The boiler is firing up, but no hot water is ever coming through. Where is all my heat going from my boiler?
The central heating still works fine. I've checked the thermostat, thats fine. The pump obviously works as the central heating works fine.
When I last had hot water problems my boiler wouldn't even fire up, but now it does and it's really confusing me!
