Broken Bleed Valve and Other Problems
30 Jan 2006
I have a comination boiler. I removed and drained one radiator to decorate, then replaced it. Since then, the system keeps losing pressure, and I have to fill it up every couple of days. I've tried turning the heat on full, with one radiator turned off and the others up high. This hasn't solved the problem. Any ideas?
Also, the bleed valve on one radiator has broken. It just turns round and round, but no air or water escapes. I guess its just the end of it that is broken. Can I replace this part of the radiator or am I going to have to replace the whole radiator.
Thanks for any help!
I expect you repressurised too high and it's now dripping through the pressure relief valve to the outside. Fix this first, then get the expansion vessel checked, then ask/beg at your local plumbing merchants for a bleed screw off a damaged rad.
Thanks for the reply.
I've got an old radiator so may be able to get my plumber to remove the valve from that one.
Cheers
Cheers
Remove what valve?
Remove bleed screw do you mean? The snapped one on your rad can be drilled out but you will need to find a bolt (with ptfe) to replace it with. Ive used 1/8" plugs on expensive rads to save customers the cost of replacing it.
PRV may be able to repair. Unscrew head, smear with silicone grease and re-assemble. (System drained of course).
Reference section has posts on checking e/vessell pressures.
David
