Anyone here with any experience of this? Please bear with me this is a bit of a saga!
In July 2008 after a heavy storm my basement drain backed up. (There is very little fall on it between the appliances and the main sewer in the centre of the street). As a consequence effluent backed up the pipe a way and blocked it. This used to happen roughly every 6 Months and always after heavy rain.
Anyway called the council as we have done on the previous occasions and they sent the wagon round to jet the drain from a small inspection access in the front of the property. Jetting the drain involves pumping water under high pressure down through a steel ball with strategically placed ports allowing it to move forward.
After about 10 minutes it became apparent the council chap couldn't get his hose back out of the hole and he reported it would have to be dug out. They cut off the hose and departed.
Local Authority then served notice for us to rectify the drain blockage. We contacted our buildings insurers and a plan was put in effect with the agreement of the EHO that a saniflow would be fitted in the basement and the waste re routed to another foul drain.
This all took place over about a 6 week period was was essentially complete around September 2008.
Fast forward to November 2010 when part of the centre of the street outside started to subside (a small hole appeared growing larger over several days). Hole was reported and council investigated. a week or two later a road crew arrived and opened the road did a couple of days work re surfaced all and departed.
February 2011 and a bill arrived on my mat this morning for a bill for £3200+ for repairing what they say was my drain. The paperwork goes into a little detail with work and time sheets for the people employed in the project and hire of the kit they have used.
The description of the work is 'Excavate in carriageway to investigate subsidence, install shoring, discovered broken pipework from number 22 with jet washing hose stuck inside repair as required'.
Couple of questions if I may of anyone with any experience in this area.
Is it possible the jetting eye under a high pressure water stream could have broken the pipe?
Is it reasonable for me to assume the Local Authority have some liability here.
Is the LA not required to serve some sort of statutory notice upon me before they conduct this work?
As I understand it the subsidence could only really have been caused by spoil being washed away down the drain through the break? As soon as this drain became blocked with the hose it became unusable and indeed redundant as soon as the saniflow was fitted.
Clearly if it is my responsibility and the council completely blameless then I will pay for the repair. My buildings insurance covered the initial problems and they met the cost (less the excess) for the fitting of the saniflow. I am yet to discover if this settlement was a full and final one meaning I have no further cover!
If you have read this far then I thank you. If you can shed some light on my problems by way of experience I would be grateful.
