My daughters has recently moved into a different house, and had a new consumer unit proffesionally fitted with mcbs and rcd as the old unit was 30 years old. Whilst decorating and changing sockets on the ring main we found a socket that had the earth wire snapped short on one of the cables so it would not fit into the back of the socket.(cable tight with no slack) It had been extended into the socket using a new piece of earth wire and a screwed 15 amp plastic terminal block joining the 2 earth cables , is this safe.? It does not seem to be causing a problem at the moment.
thanks
Foundry
thanks
Foundry
