C
ColinJacobson
In 1960s house. There is a wall hung toilet on the ground floor. The plastic drain stack is on the other side of the wall in duct. The tee is just above floor level going to the wc.
There was damp on the wall and further investigation showed it was the joint where the earthenware drain came in from the outside chamber and connected onto the plastic soil stack. Cement fills the gap between the plastic and the earthenware socket. The earthenware pipe is just above the concrete floor level.
A part of the earthenware socket was cracked and this is were the water was getting out. A piece of the socket has broken away leaving a hole. The piece can be placed back in to fill most of the hole.
How is the joint made up in this case?
Portland cement?
If Portland cement does it need mixing with sand?
Can small bags be bought from merchants?
There is some floor space around the joint to mound up any cement.
The toilet is out of use and the cloakroom toilet is being used.
Any input would be appreciated.
Portland cement?
