broken flush button
14 Feb 2012
Manchester
Hi.
We have a single flush toilet button which is broken. I cannot fit it onto the fixings inside the cistern (it falls off) and won't attach properly. We can flush the toilet by pressing the white plastic tube which i can access through the hole where the button was. As you can tell, I'm no plumber...i don't know what to do to fix it. Am i able to buy just the round flush button on it's own, if so, where from? If not, what do i need to buy? I have added photos to explain things easier.
Any help would be very much appreciated. Thanks
The top of the white rod looks threaded. Have you tried screwing the button on to it?
Your button's broke.
The top outer ring has broke away from the chrome part still on the flush valve.
New button about £12.
Thank you both, really appreciate your help. I couldn't screw it back on, I will buy a new button. It says siamp on the white plastic inside the cistern, no other info. Should any single flush siamp button fit?
