Broken tile unmovable due to cemented ridge tile - advice needed
8 May 2013
Norfolk
Hi!
So one of our roof files has broken and I need advice to replace it.
The tile immediately above the broken tile runs under the ridge tile and there is a lot of cement keeping that tile totally ridged and unmovable- so Im unable to lift it to remove and replace the broken tile.
Im thinking the only way to fix this is to chisel away the cement on the ridge tile to remove the ridge tile and them I should be able to lift the tile out and replace it. The cement everyting back in place.
Does this sound like a sensible option? - Id hate to do this and someone tells me there is a better way todo it.
ps.... Unfortunately the tile is snapped into 4 sections and those sections are lost. I had hoped I could glue it back together, but that impossible.
The correct way would be remove the ridge, replace tile re bed ridge.
This can go easy often not!
Sometimes a small angle grinder can help if the mortars hard.
you may have to remove more than one ridge tile as the adjacent tile to the broken one needs to lift in order for the lugs to lift over the battons?
litl
litl
I was thinking that too. It depends how much wiggle room there is and the position of the ridge relative to the bosted tile.
