Broken Toilet Soil Pipe
15 May 2008
Devon
Hi, I have just broken the metal toilet soil pipe insde the wall. Can you buy a connector that will fit insde the broken pipe?
Thanks Dave
You could plausibly fit a piece of plastic pipe into the pipe as an inner sleeve but not a good idea, wouldn't be able to get it to seal properly for one and it's just not right. To repair a cast iron downpipe you need to cut the broken section out and fit a flex rubber connector in or replace the whole shebang.
I wouldn't be putting any sort of a joint inside the wall. (If it leaks you may not realise until it's too late!) Replace the section through the wall complete.
Do what Madrab says and cut it out or if access is easy enough change the whole pipe to plastic.
