Broken Window - Spotlight glass
21 Nov 2011
Stirlingshire
Any one know where I might get a small piece of glass of the pattern called "spotlight". My roofer broke one of the 28 panes of the "spotlight" pattern in my leaded glass window and I need a tiny bit around 50mm wide by 250mm tall. The window was put in around the early 1960s when a previous owner built an extension. I believe the pattern is no longer manufactured. Many thanks.
I had a stained glass / leaded glass specialist look at he same photos and he said exactly the same, but when he arrived to fit the hammered glass he realised that the hammered glass is a much larger pattern.
He then went away and did some research on the glass in my window and has identified it as "spotlight" glass, form the early sixties, so this is what I am going on.
The pattern is dimpled with horizontal striations between the dimples. Each dimple is only about 4 or 5 mm in diameter.
You wouldn't have a photo of the pattern you have , would you?
jayarr
