Brown Dirty Hot water
30 Dec 2003
Just had plumber round to install new expansion Tank and I am wondering how long I could expect brown dirty water to last?
I have filled at least 5 bathfulls and still seems to be dirty any ideas?
Do you have a water cylinder ?
What was wrong with the old F&E tank ? or do you mean cold water storage tank?
Basically, turn the boiler off, so the water is not getting heated (so you dont waste gas/electric), and just run the water until it runs clean. Its because few people bother to flush their tanks over the course of its life, so muck accumulates in the bottom of it. When the tank is run dry, the muck at the bottom of the tank is disturbed when water is added again, and must be run off with the water.
This is a new tank so I wouldn't of thought there be too much dirts etc....
I was wondering if it is by-passing via the cylinder coil but need more information first...
Edit - spelling error
It is a small 12L expansion vessel connected to my hot water tank I wonder if it is just the (water and membrane of vessel getting washed for first time flushing out?
Normally the expansion tank is the feed for the heating system and the cold water storage tank is the feed for cylinder plus water supply.
Really need to know what type of heating system you have.
Actually, both tanks are considered "Feed and Expansion" tanks.
I assumed you meant your "cold water storage tank" had been replaced.
The expansion tank is the one in the loft(usually). The cylinder is the one that holds the hot water. Both contain muck after years of accumulation. If you empty them, and then fill them again, either will produce dirty water.
