Hi All
We had one of these boxes fitted by National Grid yesterday and BG then installed a meter inside the box.
I have just checked inside the box and it is full of rainwater - i emptied it out the best i could but it is slowly filling up again so i assume the water is coming up through the hole in the bottom of the tank which the gas pipe passes through.
The box seems very low to the ground - the front end is actually below ground level and the back end is practically at the same level of the ground. I have driven around the area and the other brown boxes i have seen all seeem to be about 3-4 inches above ground level (the front end of the box). Does anyone know if water inside the meter is normal ?
I am going to phone National Grid tomorrow to ask them as i am sure the installtion has not been done right but would like to hear from anyone else who has experienced water in the box ?
Many thanks
Many thanks
