The kitchen cold tap and bath cold tap upstairs are both fed from mains. The last couple of days when we run a bath for our boy, the water has a brown tint and there is tiny rusty bits settled on the bottom of the bath.
After some experimentation this is what I've found:
- The bath cold tap is the source of the brown water
- The kitchen tap runs clear when the bath tap is OFF and runs the same brown when the bath tap is ON
- Hot taps run clear
- Heating F+E tank level is normal with no signs of overflow although lots of rusty powder settled at the bottom
- Water header tank is normal and water is clear
- Running bath tap for ten minutes does not clear the water
Any ideas? There can't possibly be a connection between the mains and the heating circuit right? Except through the hot tank and then the hot water would be affected?
Neighbours haven't noticed anything. Water board say nobody else in the area has called about this.
