Gosh it's cold. 13 deg C at floor level, 16,5 deg C at ceiling.
In a ground floor flat built c. 1926. GCH, DG throughout, good fitting external doors ("Fit the best ... Ever felt you've paid over the odds),
CWI in ext brick walls. which are harled, they are painted every 2 years for waterproofing
There's nothing in the way of internal insulation - floors, ceilings, walls. I had to retrofit the GCH piping with 9mm Class O Armaflex.
Floors are wooden tongue and groove floorboards except in kitchen which is solid concrete, most probably without an insulant layer installed.
Ceilings are lath and plaster except in kitchen which is solid concrete.
Internal walls are mainly lath and plaster. except load bearing walls which are brick and plaster.
The council offered to do underfloor insulation for a price (I own the place) when they were doing tenanted properties but they moaned about the lack of depth underfloor .. health and saftey innit. They also haven't made a very good job of the council properties' insulation I've seen done.
Have noise problems from neighbours upstair. Was thinking 2 by 15mm acoustic plasterboard sheets on ceilings .. a WIP. Should this be augmented with anything else in the space between ceiling joists? Same for walls so I can listen to music louder.
What's my best (fibreglass free) strategy for further insulating the place, a bit at a time?.
Anything, low footprint I can line the interior surface of external brick walls with?
I've got access to sprayers, laggers, surplus insulation boards from the skip etc.
Thermal resitance figures would be extremely useful.
