Hello all,
I've just sorted out getting a landline from BT and broadband package for a property I've recently moved into. Alas, there is no master socket. I know you're not supposed to connect these things yourself but the £125 connection charge was a bit off putting so I've had a go.... and as far as they were concerned there should have been one in the house already.
... seen all the discussions and read about the way to wire the things. Found a four core wire in a grey box just outside my door which had been cut. Got the blue wire going to terminal 2 and the blue/white going to terminal 5 but nothing happens when I plug the phone in (have tried every other possible combination/ checked with a volt meter and the two wires are 'live'). Is there something I'm missing? Just wanted to check before I give in and get a BT engineer out.
Cheers
Cheers
