Was wondering if you can help please? Long post sorry, but thought I should give all the relevant detail!
We are decorating our living/dining room for the first time since we moved in 2 years ago. I have never painted before either, but I did a fair bit of research first.
I have just put the first coat of matt emulsion (it's Ecos organic/eco paint if that makes a difference) onto a previously painted wall using roller, and in a few areas there are small but numerous air bubbles appearing.
Before starting to paint we filled and sanded down any holes/cracks (but didn't sand the whole wall). Then brushed off dust then washed all walls with sugar soap, then rinsed and let dry. Rollers and brushes were all new, so really dont think any dust/grime could be the cause. This is what most websites seem to suggest as the cause of bubbles, so need to know what else it can be?
The main wall affected is an interior dividing wall. After finding bubbles, I tried sanding down and doing a skim of polyfilla superfine then re-paining the areas. This seemed to work on most areas but the dividing wall just came up in new blisters slightly higher up. These ones I tried popping with a pin then pressing down, it did seem to work, weirdly! But I'm worried they'll come back when I do the second coat. In one area (on the inside of the dividing archway, so the cross-section of the wall) the old paint came off in quite big rubbery-like strips, so the old paint might be latex paint of some sort I guess?
So I'd like to know what I should do, should I just sand a huge area right down to plaster, and if so, do I need to do the whole wall to get it even-looking, and what should I then do before re-painting? As we were just painting over painted surfaces I don't have any primers/sealers to hand, but can buy if necessary.
Also, I assume they used the same paint in the rest of the house, so if the old paint is the issue, what should I do ideally to stop it happening in future in another room?
Really appreciate your help, husband has no clue and is not as involved in this whole thing as me!
Thanks v much
Thanks v much
