I'm new here but not to DIY. Hopefully in future I can help others with my knowledge but now, I need your help.
So, I have an open vented system with newish cast iron rads and suprima boiler. Ever since I've lived in the flat (3 years) I've had the following problem:
1. Pump circulates water when cold and no bubbling at the pump
2. As the boiler heats up there is an increased intensity of noise at the pump from air rushing by.
What I have tried:
1. Blocked off the overflow pipe in case air entering the system here. Makes no difference.
2. Run the pump without the boiler to see if air being sucked in somewhere. It is not.
3. Suspect sludge/magnetite. Flush the system and use Fernox DS40. No difference.
5. Fit Fernox TF1 to collect magnitite. No difference.
4. Remove every radiator and wash out with hose. Quite a bit of magnitite but no difference.
5. Remove HEX and flush out. Lots of magnetite. Boiler quieter but still bubbling at the circulation pump when hot.
6. Drain down, water looks clean.
7. Remove HEX and clean with hydrochloric acid. HEX now looks clean and flushes absolutely clean. Still no bl**dy difference.
Circulation is fine - all rads get warm, top to bottom.
I'm really at a loss about this and it is driving me absolutely mad. Help much appreciated.
Thanks,
Alan
What I have tried:
Thanks,
Alan
