Hi
I have a very persistent bubbling noise coming from my central heating system. The system worked fine until I replaced a radiator last Summer.
The system is conventional with the two cold water tanks in the loft and is powered by an oil fired Worcester boiler at the lowest point (kitchen). I have it set to heating only, hot water being provided by economy 7 heating element in the hot water tank. Most of the system is microbore however some 7 years ago the boiler was changed and a new extension fed from it using conventional 15mm piping. It has all been fine for 6 years.
The noise occurs when the system starts up first thing in the morning. There is a loud bubbling that goes on for around 30 seconds that can be heard upstairs in the master bedroom. I have tried bleeding all radiators including the vent next to the hot water tank and the pump. I have done this around a dozen times. The pump only bleeds when running. Very ocassionaly I find a radiator that is only 75% full of water. Normally all is fine.
More recently the pump started to make a loud noise when running. To solve this I turned it down to its lowest setting (It was set to the middle setting before). The pump noise has abated but the bubbling remains. I have checked the cold water feeds. All is OK (I had to adjust the heating water tank ballcock as the level was high but its not filling past that point or anything suggesting a leak in the hot water cylinder coil.)
I am at a loss now.
Thanks!
I am at a loss now.
Thanks!
